Identity and contact pair
I am trying to build a model in which it is not contacting in geometry but continuous in physical quantity between two surfaces in 3D model. So I use the "form an assembly" to build the model and define a identity pair between the two surfaces mentioned before. At the same time, I define a continuity boundary condition under the physics node and use the 'copy face' to establish the mesh for this identity pair.
However, I don't get the right result, for the voltage in the object is not gradiently distributes, which means that this identity condition setting is not correct.
But when I use the contact pair instead, I get the result which I need.
Thank you!
1 Reply Last Post 26 mar 2013, 13:02 GMT-4
Posted: 1 decade ago 26 mar 2013, 13:02 GMT-4
strange, as "contact pairs are for setting up contact physics for "solid" in caontact, identity pairs with continuity is the "natural default"
Hi strange, as "contact pairs are for setting up contact physics for "solid" in caontact, identity pairs with continuity is the "natural default" -- Good luck Ivar
