Solidworks model meshing issue
I created geometry of a saddle coil pair in Solidworks and then I imported it to COMSOL using the geometry import option. When I build meshes, it gives error of meshing around edges and corners.
COMSOL imports edges and surfaces. How can I import the part as a solid geometry?
I used livelink for solidworks too and got the same error.
2 Replies Last Post 8 mag 2013, 13:59 GMT-4
Posted: 1 decade ago 27 mar 2013, 16:14 GMT-4
strange, as normally SolidWorks imports 3D bodies as 3D bodies and not surfaces and lines only, have you checked the options for import, and could it be that you need a higher resolution as you might have some "small" or thin features?
And what about versions ? check compatibility !
Hi strange, as normally SolidWorks imports 3D bodies as 3D bodies and not surfaces and lines only, have you checked the options for import, and could it be that you need a higher resolution as you might have some "small" or thin features? And what about versions ? check compatibility ! -- Good luck Ivar
Posted: 1 decade ago 8 mag 2013, 13:59 GMT-4
Comsol imports 3D objects. If you are interested, you can check for the surfaces and edges as well!
Check the import option; you will be able to resolve the issue!
Comsol imports 3D objects. If you are interested, you can check for the surfaces and edges as well! Check the import option; you will be able to resolve the issue!
