Nagi Elabbasi
Facebook Reality Labs
2 apr 2013, 23:26 GMT-4
Hi Philip,
If you are imposing the temperature distribution then just use the Solid Mechanics physics, activate the Thermal Expansion sub-node of the Linear Elastic Material (or whatever material you are using), and enter the temperature field in the Settings Window.
Nagi Elabbasi
Veryst Engineering
Hi Philip,
Nagi Elabbasi
Veryst Engineering
3 apr 2013, 00:27 GMT-4
I am unable to locate the particular subnode that you recommended using. You solution sounds as if it would be very beneficial if I could locate the subnode. Could you advice me as to where this subnode would be located for version 4.3a?
Thank you.
Thank you.
3 apr 2013, 01:42 GMT-4
Hi as Nagi said:
"Thermal Expansion sub-node of the Linear Elastic Material" (right click Linear Elastic Material node)
bt there might be some need for HT and SOLID to get that ? (I cannot tell as I have both, and I'm not by my WS to test it out)
Henrik Sönnerlind
COMSOL Employee
3 apr 2013, 01:56 GMT-4
A license for Structural Mechanics or MEMS.is required for having access to the Thermal expansion subnode. Check under Options->Licences.
Henrik
Henrik
9 apr 2013, 00:08 GMT-4
Thank you.
It was a license issue and it was resolved and the problem was solved. Thank you again
Thank you.
9 apr 2013, 00:09 GMT-4
Thank you.
Thank you.
Thank you.
Thank you.
29 set 2013, 02:13 GMT-4
Dear Philip,
I have a same problem with you. And I check in my license. I dont see the tick at the structural mechanics module. But I can not click it. Could you tell me some more about your solutions?
If you have any advices, can you tell me here or at my email: n1301790g@e.ntu.edu.sg
Dear Philip,
