Extrap
Posted 9 apr 2013, 05:23 GMT-4 Fluid & Heat, Computational Fluid Dynamics (CFD), Geometry, Materials, Modeling Tools & Definitions, Parameters, Variables, & Functions, Results & Visualization, Studies & Solvers Version 4.2a, Version 4.3, Version 4.3a 1 Reply
I am doing a CFD simulation in which I need to use the solution of another CFD simulation. I need to take a "slice" of the solution and use it in another geometry. As I understand, there are two ways, one is to import the data and use it in another file and the other way is to couple two models in the same file.
I have tried the second way with satisfactory results but I want to try the other one. I exported the data as a spreadsheet in a .txt file and I used an interpolation function in the new file. I inserted the interpolation function at the inlet of my geometry (in the laminar flow moduel settings: inlet) and tried to solve.
I have an error called "Extrap not supported. Error in multiphysics compilation". So far I have not found any entry or thread about this error. Either the solution is too simple or this error is not so common, I asume is the first one. What can I do? I am sure I missing something but I can't find it
Regards and thank you in advance
Miguel
