Problem with Mesh when sweeping a geometric parameter
Posted 9 apr 2013, 19:54 GMT-4 0 Replies
I have been able to sweep the wavelength with a parametric sweep to get a nice spectrum for the device. I now want to sweep the height of the air gap and the wavelength at the same time by adding it to the same parametric sweep as the wavelength. When I try to this, I get the error "You must specify the destination."
I've traced this back to the mesh node. I've used the Copy Edge feature to match the mesh at the edge of my model where I have periodic boundary conditions. Apparently, trying to sweep the geometry in this way depopulates the selections used in Copy Edge. To repair the model, I then have to revert to the last saved state. Whenever I change the air gap manually, my geometry and my mesh both update correctly. Is there a way I can make this work properly using a parameter sweep?
Thank you,
Will
Hello Will Streyer
