model eye and its saccades
I'm trying to model the eye and have it oscillate about it's axis with an angular velocity.
However, when I use moving mesh to create movement, I can't seem to get it to rotate about it's axis (the origin). It seems to oscillate just in the y-direction. I'm relatively new to Comsol so any kind of help will be great!
I've attached my mph file too.
Thanks!
Karthik
2 Replies Last Post 22 apr 2013, 12:53 GMT-4
Posted: 1 decade ago 19 apr 2013, 15:47 GMT-4
you might want to define a cylindrical coordinate and define your motion w.r.t. that one
(Model - Definitions - Coordinate Systems)
Hi you might want to define a cylindrical coordinate and define your motion w.r.t. that one (Model - Definitions - Coordinate Systems) -- Good luck Ivar
Posted: 1 decade ago 22 apr 2013, 12:53 GMT-4
Hi Karthik,
The problem is that you are applying a constant circumferential velocity. In order to get a rotation the applied velocity should linearly increase with distance from the center.
Nagi Elabbasi
www.veryst.com
Hi Karthik, The problem is that you are applying a constant circumferential velocity. In order to get a rotation the applied velocity should linearly increase with distance from the center. Nagi Elabbasi www.veryst.com
