Voltage Induced in a Coil by Moving Magnet
I am trying to learn how to use moving mesh. And I created a project same as "Voltage Induced in a Coil by Moving Magnet", which can be found in Comsol website. But the problem is: when I run it, an error always occurs like: Nonlinear solver didn't converge...
I am very sure I follow every instruction from the Documentation. So, does anyone get this model run?
And I have a question about the "study settings" described in the documentation, in which it is stated that: Step 1: Stationary; Step 2: Time dependent...' Could anybody show me more detail about this part? Thank you!
My comsol version: 4.3
6 Replies Last Post 10 nov 2014, 07:51 GMT-5
Posted: 1 decade ago 3 mag 2013, 21:32 GMT-4
First, as I know, this is a model used in COMSOL 4.3a, not 4.3. So, it may be your code version is not the latest.
Seconly, this model can be solved correctly when I follow the instruction document. I also faced the "Nonlinear solver didn't converge." problem once, but in the end I find that is because I forget chose one boundary.
Thirdly, the "study settings" is also mentioned in the document: the paragraph above "Step 2; Time Dependent", and it said "Time Dependent study automatically takes the initial values for the vector potential from the stationary solution"
Good luck!
First, as I know, this is a model used in COMSOL 4.3a, not 4.3. So, it may be your code version is not the latest. Seconly, this model can be solved correctly when I follow the instruction document. I also faced the "Nonlinear solver didn't converge." problem once, but in the end I find that is because I forget chose one boundary. Thirdly, the "study settings" is also mentioned in the document: the paragraph above "Step 2; Time Dependent", and it said "Time Dependent study automatically takes the initial values for the vector potential from the stationary solution" Good luck!
Posted: 1 decade ago 4 mag 2013, 17:09 GMT-4
Thank you! Yes, I am using comsol 4.3 which might be different from 4,3a.
So, I have two questions: 1.when you come to "STUDY" setting: for step1, you put a "X" to moving mesh, but do you need to put a "check" for Magnetic fields? 2. Could you please tell me the settings for step 2? i.e. are both of the two parts be checked or one "X" and one check?
Thanks a lot!
Thank you! Yes, I am using comsol 4.3 which might be different from 4,3a. So, I have two questions: 1.when you come to "STUDY" setting: for step1, you put a "X" to moving mesh, but do you need to put a "check" for Magnetic fields? 2. Could you please tell me the settings for step 2? i.e. are both of the two parts be checked or one "X" and one check? Thanks a lot!
Posted: 1 decade ago 6 mag 2013, 04:02 GMT-4
In step one, you add a “×” to "moving mesh",and leave the "magnetic fields" no changed, ie “√”.
The settings for step2 is both two parts be checked, ie “√”.
Good luck!
In step one, you add a “×” to "moving mesh",and leave the "magnetic fields" no changed, ie “√”. The settings for step2 is both two parts be checked, ie “√”. Good luck!
Posted: 1 decade ago 2 lug 2013, 15:25 GMT-4
I know it is a little late~ But big Thanks!
Posted: 1 decade ago 4 lug 2013, 05:46 GMT-4
You are welcome, and wish we may have chance to exchange ideas in the future!
You may contact with the email: thomas_nust@sina.com
You are welcome, and wish we may have chance to exchange ideas in the future! You may contact with the email: thomas_nust@sina.com
Posted: 10 years ago 10 nov 2014, 07:51 GMT-5
sir, i am following the same steps. i am getting no error but the problem is that there is no induced voltage. can you tell me where i am wrong?
