results
how can i plot a line graph of load against deflection at the mid point for a 3D beam
1 Reply Last Post 25 apr 2013, 07:16 GMT-4
Posted: 1 decade ago 25 apr 2013, 07:16 GMT-4
you need first to do a parametric or continuation study for a varying load (numerous examples in the model library)
then you need to define the point or some average over a boundary, or use the Data set cut point/line ...
Then under Results Derived values define an integration or average value (displacement or w or ...) for the point, line ... => this makes a table force versus displacement, that you can plot by hitting the plot icon above the table GUI frame
Hi you need first to do a parametric or continuation study for a varying load (numerous examples in the model library) then you need to define the point or some average over a boundary, or use the Data set cut point/line ... Then under Results Derived values define an integration or average value (displacement or w or ...) for the point, line ... => this makes a table force versus displacement, that you can plot by hitting the plot icon above the table GUI frame -- Good luck Ivar
