restraining normal velocity vector in a curved surface
Posted 26 apr 2013, 12:41 GMT-4 Fluid & Heat, Geometry, Modeling Tools & Definitions, Parameters, Variables, & Functions Version 4.3a 0 Replies
I'm trying to emulate a two phase flow with the laminar single phase module, but I could not find a way to restrict the normal velocity from flowing through a curved surface.
It's like a slip wall boundary condition (U dot n) in the module, but instead I wan't to introduce a realistic shear stress.
I tried making 3 pointwise constraints where I used realdot(abs(spf.U),nx), realdot(abs(spf.U,ny), realdot(abs(spf.U,nz) at the interface, but I'm still having flow through the surface.
Is there any suggestions to prevent the flow from flowing through a curved surface, but still retains the tangential velocity?
Thank you!
TJ
Hello Pooyan Tirandazi
