Particle tracking in MATLAB and COMSOL 3.5.0.603
Win XP Pro / COMSOL 3.5.0.603 / MATLAB 2007a
Attached: MP_EM_Potential_2_1_0_track_electrons.b.zip
I am fairly inexperienced with COMSOL, but learning...
In the attached files, I have a new project that I created based on the COMSOL tutorial with 2 potential cylinders. I want to track 1e5 particles, so I am trying to use MATLAB.
The particles must originate in a confined area with random starting points in that area, random velocities in a particular range, and random directions within a certain range. I must track them until specific conditions are met. I have accomplished much of this already, but my work shows slight deviation from COMSOL, and I'd like to know why. I also don't understand exactly what I can/should keep when I make the call to "postplot(fem, ...". I have "guessed" what to keep.
In the attached zip file there is an image that show the deviation of my track from COMSOL. For the first phase of my project, I need to track particles for 10m or so, and see if they hit a target 1 cm in diameter and 0.5m long. The next phase will require tracking particles for 50m.
Q1: Why does my track differ from COMSOL? Am I using an incorrect approach to using COMSOL variables? Not the correct variables? Is it just a difference in error due to calculations?
Q2: In my call to "postplot (fem, ...", can I / should I reduce the number of variables that I pass to postplot ()? The MATLAB source code has quite a bit of extra debug code in it, but most of it is commented out, and I think that whay remains is clear enough. I'll be happy to answer any questions on or off the forum...
Thanks much,
~Rich~
0 Replies Last Post 8 mar 2010, 08:10 GMT-5
Hello Rich Messeder
