Batch Processing sj
Dear Engineers/Scientists
I am trying to simulate time dependent study a diaphragm with piezo actuator fixed from its periphery and want plot Voltage Vs deflection and also frequency Vs deflection simultaneously but it is not possible for simple simulation i have go for batch processing or some other option because it is possible with ansys to write a small code and do it but In comsol i am not able to do it because i just started using comsol due its good capability to couple different field like FSI and electrical and structural etc, I will be wonder if anybody can Help me
I will very thankful
Ikhlaq Ayub
1 Reply Last Post 2 mag 2013, 16:35 GMT-4
Posted: 1 decade ago 2 mag 2013, 16:35 GMT-4
Isn't that the parametric sweep condition with 2 parameters you want ?
If so, just check correctly how you want to mix/stock the two parameters, check the help doc
Hi Isn't that the parametric sweep condition with 2 parameters you want ? If so, just check correctly how you want to mix/stock the two parameters, check the help doc -- Good luck Ivar
