Question about Truss Module and plasticity
I am modeling a reinforced concrete beam using almost an identical model to the reinforced concrete beam that is provided in the COMSOL tutorials/models. I need to model the rebar as elastic-perfectly plastic, i.e. it is elastic until it reaches its yield strength, at which point the strain increases with no increase or decrease in stress. The rebar I am modeling will yield once the strain reaches 0.002. In the Truss module, there is only an option for an elastic analysis. Is there a way of incorporating elastic-perfectly plastic behavior into the truss module or is there another way I can simulate elastic-perfectly plastic conditions in the rebar?
Thanks in Advance
3 Replies Last Post 24 ott 2013, 06:48 GMT-4
Posted: 1 decade ago 10 giu 2013, 03:43 GMT-4
There is no built-in elastoplastic material for the truss elements. There are however ways in which you can perform such a simulation anyway.
As long as you are only increasing the external load, there is no difference between an elastoplastic material and a nonlinear elastic material. You can for example then enter Young's modulus as
E0*((abs(truss.een)<=eps_y) + eps_y/(truss.een+eps)*((truss.een>eps_y)-(truss.een<(-eps_y))))
Here E0 is modulus of elasticity in the elastic regime, and eps_y is the strain at yield. truss.een is the axial strain.
The expression is based on that stress = E * strain so that
stress = E0*truss.een when -eps_y<=truss.een<=eps_y
stress = E0*eps_y = sig_y when truss.een>eps_y
stress = -E0*eps_y = -sig_y when truss.een<-eps_y
If you have a situation where the load is not monotonously increasing, the situation is a bit more complex. The you will need to add a 'state' variable to keep track of the plastic strain, and the expression above needs a modification.
Henrik
Hi, There is no built-in elastoplastic material for the truss elements. There are however ways in which you can perform such a simulation anyway. As long as you are only increasing the external load, there is no difference between an elastoplastic material and a nonlinear elastic material. You can for example then enter Young's modulus as E0*((abs(truss.een)eps_y)-(truss.een
Posted: 1 decade ago 11 giu 2013, 11:30 GMT-4
I was thinking a solution similar to this might be possible. I very appreciate you spelling it out for me. I will give this a shot later today. Thanks again!
Byron
I was thinking a solution similar to this might be possible. I very appreciate you spelling it out for me. I will give this a shot later today. Thanks again! Byron
Posted: 1 decade ago 24 ott 2013, 06:48 GMT-4
I read the discussion and I found it very interesting.
I'm trying to replicate the elasto-plastic behavior of a cable by truss element.
The cable has a tension-only behavior.
Can you give me an example of a state variable to keep track of the plastic strain? (eg. plastic work..)
How can I implement an incremental elastic-plastic problem in COMSOL?
Is there any example?
Hi, I read the discussion and I found it very interesting. I'm trying to replicate the elasto-plastic behavior of a cable by truss element. The cable has a tension-only behavior. Can you give me an example of a state variable to keep track of the plastic strain? (eg. plastic work..) How can I implement an incremental elastic-plastic problem in COMSOL? Is there any example?
