Decyphering 'Axis Vector' error
When I attempt a Frequency Domain solution I get the following error message:
"Errors during multiphysics.
Two points describing the axis vector needs to be defined properly. "
I can't find a reference to this error anywhere. What does it mean?
5 Replies Last Post 26 feb 2017, 17:23 GMT-5
Posted: 1 decade ago 27 giu 2013, 00:44 GMT-4
I get a similar error. I recently installed Comsol 4.3b and I am trying to use the Wave Optics package but when I try to make a simple model it gives me the same error.
I don't see anywhere that will let me define the axis vector.
Does anyone have any solutions?
Thanks in advance,
Mark.
I get a similar error. I recently installed Comsol 4.3b and I am trying to use the Wave Optics package but when I try to make a simple model it gives me the same error. I don't see anywhere that will let me define the axis vector. Does anyone have any solutions? Thanks in advance, Mark.
Posted: 1 decade ago 27 giu 2013, 09:08 GMT-4
I was able to get the answer to this from Tech Support:
"The error that you are
getting is because of the use of circular port without reference axis.
Please see the attached model in which the reference axis is selected for
the Circular Port. The Circular Port Reference Axis is available only in
3D. When the Type of port is set to Circular under Port Properties,
right-click the Port node to add the Circular Port Reference Axis
subfeature. Two points are used to define the orientation of fields on a
port boundary. If there are more than two points on the selection list, the
first and last points are used. "
I was able to get the answer to this from Tech Support: "The error that you are getting is because of the use of circular port without reference axis. Please see the attached model in which the reference axis is selected for the Circular Port. The Circular Port Reference Axis is available only in 3D. When the Type of port is set to Circular under Port Properties, right-click the Port node to add the Circular Port Reference Axis subfeature. Two points are used to define the orientation of fields on a port boundary. If there are more than two points on the selection list, the first and last points are used. "
Posted: 1 decade ago 27 giu 2013, 23:52 GMT-4
Thank you very much!
I didn't see that option at all. I hope i can get this working correctly now.
Thanks again,
Mark.
Thank you very much! I didn't see that option at all. I hope i can get this working correctly now. Thanks again, Mark.
Posted: 1 decade ago 14 nov 2014, 03:12 GMT-5
thanks for this.it really works.
Posted: 8 years ago 26 feb 2017, 17:23 GMT-5
thanks. got me out of a jam.
