Induction Heating efficiency
Nestor Bolaños Rodriguez
Hi, is it there any way to calculate the efficiency of an induction heating process using comsols?
1 Reply Last Post 17 giu 2013, 02:13 GMT-4
Posted: 1 decade ago 17 giu 2013, 02:13 GMT-4
Hello Nestor,
I you can do it in measuring "electromagnetic heating [W]" on the different domains of your model.
In mf and mef physics this term is called mf.Qh and mef.Qh respectively.
So you can calculate the ratio between the term mf.Qh on a precise part and the total power dissipated on all your system.
The more simple way is to use mf physic and define a coil domain.
Best regards
Julien
Hello Nestor, I you can do it in measuring "electromagnetic heating [W]" on the different domains of your model. In mf and mef physics this term is called mf.Qh and mef.Qh respectively. So you can calculate the ratio between the term mf.Qh on a precise part and the total power dissipated on all your system. The more simple way is to use mf physic and define a coil domain. Best regards Julien
