Multi-linear isotropic hardening
Hi!
I'm working on a thermo-mechanical model (including plasticity) and I am defining a hardening function by an interpolation function because I have the stress-strain curve.
The problem is that I have many stress-strain curves, because this curve is dependent on the temperature (I have all stress-strain curves for various temperatures).
My question is, how I can define multiple curves (stress-strain) in my hardening function? A first solution that I tried, was using a temperature-dependent function that multiply one of stress-strain curve (20 ° C):
hardening * F (T)
but I want to know if it is possible to do adding all the experimental data.
Thanks and best regards!
Alberto T
3 Replies Last Post 26 apr 2016, 01:50 GMT-4
Posted: 1 decade ago 19 giu 2013, 12:30 GMT-4
Hi Alberto,
I believe you can define an Interpolation Function, set the Data Source field to File and reference a text file with the experimental data formatted according to the COMSOL format required for this feature (and described in the documentation).
Nagi Elabbasi
Veryst Engineering
Hi Alberto, I believe you can define an Interpolation Function, set the Data Source field to File and reference a text file with the experimental data formatted according to the COMSOL format required for this feature (and described in the documentation). Nagi Elabbasi Veryst Engineering
Posted: 1 decade ago 19 giu 2013, 12:43 GMT-4
Thanks Nagi!
done!!
Best regards!
Alberto T
Thanks Nagi! done!! Best regards! Alberto T
Posted: 9 years ago 26 apr 2016, 01:50 GMT-4
I have solving a similar problem. When we choose the interpolation function to input the values of yield stress, we also have to define the values for kinematic tangent modulus and isotropic tangent modulus. I know the value of kinematic mod, what value should i use for the isotropic modulus.?
Hi, I have solving a similar problem. When we choose the interpolation function to input the values of yield stress, we also have to define the values for kinematic tangent modulus and isotropic tangent modulus. I know the value of kinematic mod, what value should i use for the isotropic modulus.?
