Geometry Parametric sweep
I want to run a geometry parametric sweep.
Consider the following geometry sweep parameters:
H range(20[mm],10[mm],60[mm])
Z range(0[mm],10[mm],20[mm]+H)
The idea is that Z maximum value is against the height H of the object in the current nested iteration of Z against H.
In the first round (H=20) maximum Z will be 20+H=40. When first round of Z sweep finishes, H will become 30 and the maximum Z will be 50[mm].
This is not happening and ComSol is using the H global defined parameter.
Is it possible to force ComSol to use in the Z parameter sweep range the H value as calculated in the for the current parameter sweep step?
A simple code for that will be
for (H=1 to N)
for (Z= 1 to H)
mesh.....
next Z
next H
Thank you,
Dimitris
2 Replies Last Post 17 apr 2014, 05:44 GMT-4
Hello Dimitris Oikonomou
Posted: 1 decade ago 7 mar 2014, 16:51 GMT-5
Did you find a solution for this? I am trying to do something similar.
Posted: 1 decade ago 17 apr 2014, 05:44 GMT-4
Hello, do you find a solution to your problem? I'm actually want to add a parametric sweep to my geometry model. I have a wire electrod, and I want to run a simulation in order to see the Electric field behavior when the diameter of my electrod changes.
When i'm running the simulation, when the diameter is my variable. COMSOL doesn't change the variable. And do the calculation for the 1st value of the diameter..
Someone has an idea to deal with this problem?
Hello, do you find a solution to your problem? I'm actually want to add a parametric sweep to my geometry model. I have a wire electrod, and I want to run a simulation in order to see the Electric field behavior when the diameter of my electrod changes. When i'm running the simulation, when the diameter is my variable. COMSOL doesn't change the variable. And do the calculation for the 1st value of the diameter.. Someone has an idea to deal with this problem? Thanks
