Force calculation gives N instead of N/m
I draw two beams next to each other in cross-section (a 2D simulation) and apply 1V to one and 0V to the other, and solve for electric field. When I do a Force Calculation in COMSOL v4.3a for beam #1 I get 1.3e-11 N. When I do a force calculation for beam#2 I get the same number in negative form as I'd expect by symmetry. When I do a force calculation for a box containing both beams I get something near zero, as I'd expect. See attached file.
However my problem is, I was expecting to get a force-per-meter [N/m, not N]. Because integrating the stress tensor for such a 2D simulation should give force-per-meter, and then when you go to do a 3D simulation you apply that force-per-meter at each point along the z-dimension of the beam.
What is going wrong?
David
3 Replies Last Post 22 lug 2013, 02:58 GMT-4
Posted: 1 decade ago 22 lug 2013, 02:52 GMT-4
Hallo David,
the is a setting that specifies the thickness in the 3rd dimension and
force calculation are multiplied with this value. So instead of N/m
you get N.
Regards
Jens
Hallo David, the is a setting that specifies the thickness in the 3rd dimension and force calculation are multiplied with this value. So instead of N/m you get N. Regards Jens
Posted: 1 decade ago 22 lug 2013, 02:57 GMT-4
Thanks. Where is this? I'm clicking around but can't see that anywhere.
Posted: 1 decade ago 22 lug 2013, 02:58 GMT-4
Never mind, it's under Solid Mechanics node (or whatever type of simulation you choose).
