Maximum number of Newton iterations reached
I have imported a 3D meshed model from simpleware to COMSOL 4.3b.
Some of the materials of the model are Hyperelastic, Neo-Hookean.
While running the model via Direct Solver at 99% of progress there is an error:
-Feature: Stationary Solver1 (sol1/s1)
-Error: Failed to find a solution
Could you please help me how I can interpret this error and what the solution is?
4 Replies Last Post 21 ago 2013, 06:20 GMT-4
Posted: 1 decade ago 23 lug 2013, 01:13 GMT-4
Dear Bahram,
Plz look into the solver configuration,
under fully coupled you will find "method and termination". Go and change number of iterations.
[QUOTE] I have imported a 3D meshed model from simpleware to COMSOL 4.3b. Some of the materials of the model are Hyperelastic, Neo-Hookean. While running the model via Direct Solver at 99% of progress there is an error: Maximum number of Newton iterations reached Returned solution is not converged. -Feature: Stationary Solver1 (sol1/s1) -Error: Failed to find a solution Could you please help me how I can interpret this error and what the solution is? [/QUOTE] Dear Bahram, Plz look into the solver configuration, under fully coupled you will find "method and termination". Go and change number of iterations.
Posted: 1 decade ago 23 lug 2013, 08:50 GMT-4
Thanks for your instruction.
I increased the maximum number of iterations in different steps; however, there is the same error.
Also, in some of the number of iterations, the error is:
'Attempt to evaluate negative power of zero'
The complete text of error is attached.
Could you please help me?
Bahram
Thanks for your instruction. I increased the maximum number of iterations in different steps; however, there is the same error. Also, in some of the number of iterations, the error is: 'Attempt to evaluate negative power of zero' The complete text of error is attached. Could you please help me? Regards, Bahram
Posted: 1 decade ago 23 lug 2013, 11:58 GMT-4
I am not sure but it seems we are missing to define something i the beginning.
Posted: 1 decade ago 21 ago 2013, 06:20 GMT-4
Hi All,
I am experiencing similar difficulties. Has anyone reached a resolution for this convergence problem or managed to find a solution in spite of 'max number of iterations' error?
Hi All, I am experiencing similar difficulties. Has anyone reached a resolution for this convergence problem or managed to find a solution in spite of 'max number of iterations' error?
