Thick Cylinder under pressure
Plz tell me how can i model a thick cylinder under pressure as attached in the file.
I made a 2D model, defined material, chose "solid mechanics".
Applied a "boundary load" at inner circle boundaryand other at outer circle boundary.
I got the error "failed to find a solution" The relative error (...) is greater than the relative tolerance............
Regards
Brahmarishi
2 Replies Last Post 24 lug 2013, 04:33 GMT-4
Posted: 1 decade ago 23 lug 2013, 14:16 GMT-4
Hi Brahmarishi,
If you model the full cylinder in a static (stationary) analysis you will have a singular system with rigid body modes. That could be the problem. In that case you should model a quarter cylinder instead and apply symmetry conditions on the 2 new boundaries.
Nagi Elabbasi
Veryst Engineering
Hi Brahmarishi, If you model the full cylinder in a static (stationary) analysis you will have a singular system with rigid body modes. That could be the problem. In that case you should model a quarter cylinder instead and apply symmetry conditions on the 2 new boundaries. Nagi Elabbasi Veryst Engineering
Posted: 1 decade ago 24 lug 2013, 04:33 GMT-4
Hi Brahmarishi,
Nagi Elabbasi
Veryst Engineering
Thank you very much, i will get back to you if i have other problems/doubts.
Regards
Brahmarishi
[QUOTE] Hi Brahmarishi, If you model the full cylinder in a static (stationary) analysis you will have a singular system with rigid body modes. That could be the problem. In that case you should model a quarter cylinder instead and apply symmetry conditions on the 2 new boundaries. Nagi Elabbasi Veryst Engineering [/QUOTE] Thank you very much, i will get back to you if i have other problems/doubts. Regards Brahmarishi
