induction heating
Hello every body,
I want to know if it is possible to measure the impedance of a charge in induction heating process.
I can have lot of informations on the coil parameters (Icoil, Pcoil, Zcoil...) but how can I access to these informations on the charge?
Anyone have a idea?
Thank you very much
Julien
2 Replies Last Post 30 lug 2013, 05:54 GMT-4
Posted: 1 decade ago 26 lug 2013, 09:35 GMT-4
Julien,
an impedance is a ratio of field quantitites, in the electromagnetic case this is voltage / current (applicable for lumped components like the coil) or electrical field / magnetic field (applicable for materials with wave propagation far away from boundaries).
This way you can calculate a wave impedance for the material, similar to the way the wave impedance for free space (377 Ohm) is determined.
Have a look at en.wikipedia.org/wiki/Wave_impedance or into a textbook.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
Julien, an impedance is a ratio of field quantitites, in the electromagnetic case this is voltage / current (applicable for lumped components like the coil) or electrical field / magnetic field (applicable for materials with wave propagation far away from boundaries). This way you can calculate a wave impedance for the material, similar to the way the wave impedance for free space (377 Ohm) is determined. Have a look at http://en.wikipedia.org/wiki/Wave_impedance or into a textbook. Cheers Edgar -- Edgar J. Kaiser emPhys Physical Technology
Posted: 1 decade ago 30 lug 2013, 05:54 GMT-4
Thank you very much Edgar,
I can try to make my simulation with mef in order to have access to the calculation of the electric field
After that I can calculate
Z=E(x)/H(x) on the different geometries of the model
Best regards Julien
Thank you very much Edgar, I can try to make my simulation with mef in order to have access to the calculation of the electric field After that I can calculate Z=E(x)/H(x) on the different geometries of the model Best regards Julien
