Scattering off a gold tip
Posted 8 ago 2013, 20:05 GMT-4 RF & Microwave Engineering Version 4.3a 0 Replies
I'm having trouble with my model and was hoping someone could help me out. I am trying to model what happens when a frequency of light washes over a small tip of gold. My model is very similar to the Optical Scattering Off of a Gold Nanosphere model within COMSOL. I have successfully meshed my geometry as well as set up all the necessary parameters for the physics I am trying to solve, yet when I finally try to compute the study I get the following error message:
Failed to find a solution.
Singular matrix.
For mesh-case 0 there are 8808 void equations (empty rows in matrix) for the variable mod2.E10.
and similarly for the degrees of freedom (empty columns in matrix).
I have no real idea on what is causing the error or how to fix it so any help on the matter would be great.I included my model as well. Also the model has a lot of seemingly excess geometry but that is because I will be using the rest of it at a later time to model the heat flow within the tip of gold, however for now I don't want to solve for it which is why it is disabled.
Thank you,
Connor
Hello Connor Johnson
