Help me! Error"Internal error in boundary respecting."
Hi, all
I want fix it, It is coordinate (-2,06378, 1,35209, 2,8034)
Thank a lot
Vinh Nguyen
7 Replies Last Post 28 ago 2013, 00:07 GMT-4
Posted: 1 decade ago 20 ago 2013, 07:18 GMT-4
try to take a look at this thread www.comsol.com/community/forums/general/thread/1355/
Could you solve your problem?
Regards
Hi, try to take a look at this thread http://www.comsol.com/community/forums/general/thread/1355/ Could you solve your problem? Regards
Posted: 1 decade ago 27 ago 2013, 05:47 GMT-4
Thank a lot, I am using Solidwork to design. I feel work in it happen lots of error. If I use autocad 3D, I will control error better ?
Posted: 1 decade ago 27 ago 2013, 06:00 GMT-4
actually I don't know because I usually build my geometry directly on Comsol. Try to browse in the forum. I edited your post adding the filters "Geometry" and "LiveLink Products", maybe some users can give you useful advices!
Bests
Hi, actually I don't know because I usually build my geometry directly on Comsol. Try to browse in the forum. I edited your post adding the filters "Geometry" and "LiveLink Products", maybe some users can give you useful advices! Bests
Posted: 1 decade ago 27 ago 2013, 06:22 GMT-4
thanks Fabio Greco
I design win turbine blade, so the design direct it is difficult. You can help me provide some one documents about drawing direct on COMSOL.
look forward to receiving feedback from you
thanks Fabio Greco I design win turbine blade, so the design direct it is difficult. You can help me provide some one documents about drawing direct on COMSOL. look forward to receiving feedback from you
Posted: 1 decade ago 27 ago 2013, 06:54 GMT-4
I think it's an an hard challenge to model a wind turbine blade directly in Comsol, and it may be even impossible! Importing the geometry into Comsol through SolidWorks or others is the most wise approach!
Regards
Hi, I think it's an an hard challenge to model a wind turbine blade directly in Comsol, and it may be even impossible! Importing the geometry into Comsol through SolidWorks or others is the most wise approach! Regards
Posted: 1 decade ago 27 ago 2013, 14:27 GMT-4
I have also had similar challenges when trying to mesh thin slices of materials present in a domain. I will appreciate if anyone has a solution approach to meshing these geometries in COMSOL.
I am attaching a copy of my geometry and model here.
Hi, I have also had similar challenges when trying to mesh thin slices of materials present in a domain. I will appreciate if anyone has a solution approach to meshing these geometries in COMSOL. I am attaching a copy of my geometry and model here.
Posted: 1 decade ago 28 ago 2013, 00:07 GMT-4
I get this error when importing from solid to COMSOL. Everyone help me!
