Evaluate expression for different (specific) solutions
Hi all.
Does anybody know how to evaluate expression for different solutions at the same time? I mean something like coupling integral between several modes. For example I have an eigenvalue problem solved and need to integrate the multiplication of the first one and the second (fourth and sixth, or whatever).
Thanks for help if any.
3 Replies Last Post 4 ott 2013, 10:14 GMT-4
Posted: 1 decade ago 26 ago 2013, 11:06 GMT-4
The with() operator is probably what you are looking for. See the Reference Manual for details.
JF
Hello, The with() operator is probably what you are looking for. See the Reference Manual for details. Best, JF
Posted: 1 decade ago 27 ago 2013, 03:23 GMT-4
Thanks for your reply.
The advice was helpfull, but didn't solve the whole problem: operator 'with' deals with the same solution. That is it works if you have one solution (following Comsol terminology) of an equation, with several eigenvalues and you want to compute coupling integrals. But I also need to do that for different solutions. Different dependent variables different equations and different parameters.
Operator 'with' seems like taking only number of eigenvalue as an argument, not a number of solution.
Thanks for your reply. The advice was helpfull, but didn't solve the whole problem: operator 'with' deals with the same solution. That is it works if you have one solution (following Comsol terminology) of an equation, with several eigenvalues and you want to compute coupling integrals. But I also need to do that for different solutions. Different dependent variables different equations and different parameters. Operator 'with' seems like taking only number of eigenvalue as an argument, not a number of solution.
Reine Granström COMSOL Employee
Posted: 1 decade ago 4 ott 2013, 10:14 GMT-4
Dear Nikita,
As stated in the documentation, the with operator can be used for time-dependent problems, parametric problems, and eigenvalue problems. We can use it to access the solution at any of the time steps, any parameter value, or any eigensolution in an expression used for plotting or data evaluation. Currently the with operator does not support inner and outer solutions, so for such models it can can not be used to access any combination of inner and outer solutions. For example, we can not use it if we have a parametric sweep (outer solution) for a time-dependent study (inner solution), or a parametric sweep (outer solution) for an eigenfrequency problem (inner solution).
Reine Granström
COMSOL Sweden
Dear Nikita, As stated in the documentation, the [b]with[/b] operator can be used for time-dependent problems, parametric problems, and eigenvalue problems. We can use it to access the solution at any of the time steps, any parameter value, or any eigensolution in an expression used for plotting or data evaluation. Currently the with operator does not support inner and outer solutions, so for such models it can can not be used to access any combination of inner and outer solutions. For example, we can not use it if we have a parametric sweep (outer solution) for a time-dependent study (inner solution), or a parametric sweep (outer solution) for an eigenfrequency problem (inner solution). Best regards, Reine Granström COMSOL Sweden
