about parametric sweep and optimization
I built a reaction model, I want to know the equilibrium states of the reaction at difference concentration of one material. so I use the parametric sweep to calculate the equilibrium results.
but when I want to regress the equilibrium parameter of the reaction with experiment data.
I can't find how to use optimization tools to finish it.
could you please tell me how to use optimization with parametric sweep?
thank you,
1 Reply Last Post 30 mag 2014, 05:57 GMT-4
Hello Feng Song
Posted: 1 decade ago 30 mag 2014, 05:57 GMT-4
Im also interested in doing optimizations for several parameter values, is this not possible in COMSOL? Is there a way to avoid manually optimize for each parameter value?
I want to generate a smooth graph where all points are optimized.
Im also interested in doing optimizations for several parameter values, is this not possible in COMSOL? Is there a way to avoid manually optimize for each parameter value? I want to generate a smooth graph where all points are optimized.
