casting of aluminium alloy
i want to model the fluid flow during casting of al-si alloys. I have solved the model for laminar fluid flow but i cannot distinguish the point at which the alloy solidifies and velocity becomes zero before leaving the outlet.
2 Replies Last Post 20 lug 2016, 01:56 CEST
Erik Bornhöft COMSOL Employee
Posted: 1 decade ago 13 set 2013, 14:39 CEST
Dear Mridusmita Sarma,
although I cannot help you with your specific model, I would like to point you to two example models from our model library you might find useful as they are dealing with metal casting processes (they are also available from the COMSOL GUI in "View>Model Library"):
www.comsol.de/model/continuous-casting-382
www.comsol.de/model/fluid-structure-interaction-in-aluminum-extrusion-4386
There are also general models about phase change available, e.g.
www.comsol.de/model/phase-change-474
Hope that helps!
Erik
Erik Bornhöft
Senior Technical Sales Engineer
COMSOL Multiphysics GmbH
Robert-Gernhardt-Platz 1
37073 Göttingen
Germany
Knowledge Base:
www.comsol.de/support/knowledgebase/browse/900/
COMSOL Blog:
www.comsol.de/blogs/
Dear Mridusmita Sarma, although I cannot help you with your specific model, I would like to point you to two example models from our model library you might find useful as they are dealing with metal casting processes (they are also available from the COMSOL GUI in "View>Model Library"): http://www.comsol.de/model/continuous-casting-382 http://www.comsol.de/model/fluid-structure-interaction-in-aluminum-extrusion-4386 There are also general models about phase change available, e.g. http://www.comsol.de/model/phase-change-474 -- Hope that helps! Best regards, Erik ********************* Erik Bornhöft Senior Technical Sales Engineer COMSOL Multiphysics GmbH Robert-Gernhardt-Platz 1 37073 Göttingen Germany Knowledge Base: http://www.comsol.de/support/knowledgebase/browse/900/ COMSOL Blog: http://www.comsol.de/blogs/
Posted: 9 years ago 20 lug 2016, 01:56 CEST
I do not understand how the mold cooling works in the continuous casting example (.mph available on COMSOL website)
Where is flow rate of water in mold defined?
I do not understand how the mold cooling works in the continuous casting example (.mph available on COMSOL website) Where is flow rate of water in mold defined?
