Joule heating error implementing insulator
I'm new here and quite desperate. I try to simulate the heat distribution between 2 conductors separated by a glass insulator. The moment I apply SiO2 as material the simulation stops working. If I change to another material, it's okay again - of course the results are useless. There seems to be no missing parameter in SiO2. What could be the problem?
/André
2 Replies Last Post 7 ott 2013, 08:57 GMT-4
Posted: 1 decade ago 4 ott 2013, 08:08 GMT-4
André,
if you are using the ec application mode, you should give the insulator a very small electrical conductivity to improve the stability of the solver.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
André, if you are using the ec application mode, you should give the insulator a very small electrical conductivity to improve the stability of the solver. Cheers Edgar -- Edgar J. Kaiser emPhys Physical Technology http://www.emphys.com
Posted: 1 decade ago 7 ott 2013, 08:57 GMT-4
thanks for the quick reply. It actually works if I set the conductance to a finite, but low value. Didn't think so, since the heat transport simulation works and the electrical conductance would have just insulated the interface. Thanks for the tip!
André
Hi, thanks for the quick reply. It actually works if I set the conductance to a finite, but low value. Didn't think so, since the heat transport simulation works and the electrical conductance would have just insulated the interface. Thanks for the tip! André
