can we use deformed geometry from one physics to analyze it other physics?
Fnu Mohammed Taqiuddin
Dear ALL,
I have a question,i have results from one physics(deformed geometry) and i want to use it for further analysis in other physics.is there any way to do it.
i have attached my deformed and un-deformed geometry pics.
please let me know if it can be done in any way.
thanks
8 Replies Last Post 1 set 2015, 09:05 GMT-4
Posted: 1 decade ago 7 ott 2013, 22:26 GMT-4
how about this:
1. right-click results>data sets>solution 1(if solution 1 includes the deformed geometry's solution), click remesh deformed configuration.
2. right-click meshes>deformed configuration, click export to file.
3. select file type and insert filename path.
4. click export.
5. right-click geometry, select import.
6. choose the file you exported in 4.
done!!!
how about this: 1. right-click results>data sets>solution 1(if solution 1 includes the deformed geometry's solution), click remesh deformed configuration. 2. right-click meshes>deformed configuration, click export to file. 3. select file type and insert filename path. 4. click export. 5. right-click geometry, select import. 6. choose the file you exported in 4. done!!!
Posted: 1 decade ago 8 ott 2013, 12:53 GMT-4
hi TAE,
many thanks for the reply.
but for some reason when i try it,i still get same undeformed geometry after exporting it.
can you name or point an example of that kind so that i ca go through?
once again thanks
hi TAE, many thanks for the reply. but for some reason when i try it,i still get same undeformed geometry after exporting it. can you name or point an example of that kind so that i ca go through? once again thanks
Posted: 1 decade ago 11 ott 2013, 00:32 GMT-4
I uploaded test.zip file.
In test.mph file, there are two Models. One is the moving mesh and structural mechanics, another is heat transfer.
after solving the first model, i exported test.mphtxt using the procedure I mentioned before.
and then,
I imported it in the geometry section. you can find the geometry that is deformed.
thanks
Hi, I uploaded test.zip file. In test.mph file, there are two Models. One is the moving mesh and structural mechanics, another is heat transfer. after solving the first model, i exported test.mphtxt using the procedure I mentioned before. and then, I imported it in the geometry section. you can find the geometry that is deformed. thanks
Posted: 1 decade ago 11 ott 2013, 01:20 GMT-4
hi TAE,
i cannot open the zip file you attach.
can you attach it again please.
many thanks
hi TAE, i cannot open the zip file you attach. can you attach it again please. many thanks
Posted: 1 decade ago 11 ott 2013, 04:05 GMT-4
I attached test.mph file.
thanks.
Note : If you want to get a deformed geometry, you need to setup the moving mesh interface.
Hi, I attached test.mph file. thanks. Note : If you want to get a deformed geometry, you need to setup the moving mesh interface.
Posted: 1 decade ago 14 apr 2014, 20:29 GMT-4
how about this:
4. click export.
done!!!
Hi, Tae,
Thanks for this instruction, it works in GUI. Do you know the matlab script for the steps 2-4.
I tried to implement the export of deformed geometry automatically but can not find the matlab script.
Hope you can still reach this post~
[QUOTE] how about this: 1. right-click results>data sets>solution 1(if solution 1 includes the deformed geometry's solution), click remesh deformed configuration. 2. right-click meshes>deformed configuration, click export to file. 3. select file type and insert filename path. 4. click export. 5. right-click geometry, select import. 6. choose the file you exported in 4. done!!! [/QUOTE] Hi, Tae, Thanks for this instruction, it works in GUI. Do you know the matlab script for the steps 2-4. I tried to implement the export of deformed geometry automatically but can not find the matlab script. Hope you can still reach this post~
Posted: 1 decade ago 6 nov 2014, 17:56 GMT-5
Hi, I have the same problems.
Could you find the Matlab script for exporting the deformed geometry?
Please share to me if you got this.
Thanks very much.
Hi, I have the same problems. Could you find the Matlab script for exporting the deformed geometry? Please share to me if you got this. Thanks very much.
Gerardo E. Villarreal-Garcia
Posted: 9 years ago 1 set 2015, 09:05 GMT-4
Thanks Tae! This was extremely useful!
Gerardo Villarreal
PhD Student
Centre for Quantum Photonics
H.H. Wills Physics Laboratory
University of Bristol
Tyndall Avenue
Bristol
BS8 1TL, UK
Office 1.25
Email: Gerardo.VillarrealGarcia@bristol.ac.uk
Thanks Tae! This was extremely useful! -- ------------------------- Gerardo Villarreal PhD Student Centre for Quantum Photonics H.H. Wills Physics Laboratory University of Bristol Tyndall Avenue Bristol BS8 1TL, UK Office 1.25 Email: Gerardo.VillarrealGarcia@bristol.ac.uk
