Hello Anderson Singulani
10 years ago
9 dic 2014, 10:30 GMT-5
Hi!
I get the same warning during a simulation of heat transfer in fluids and solids. Did you find out what it means?
Judith
Hi!
Judith
10 years ago
10 dic 2014, 02:09 GMT-5
my best guess is that the coherence between the different fluxes calculated over your boundaries is not precise enough for a given criteria, could be a too course mesh or some singularity points.
Have you tried to do some local mesh refinements ?
10 years ago
10 dic 2014, 02:40 GMT-5
Hi Judith!
To be honest, I still don't know precisely what Comsol try to inform us with this message, but I had the same interpretation as Ivar. A finer mesh didn't help me back there, but I simplified a bit the geometry and after that the warning disappeared.
Kind regards,
Anderson.
Hi Judith!
Kind regards,
Anderson.
Henrik Sönnerlind
COMSOL Employee
10 years ago
10 dic 2014, 05:11 GMT-5
This message appears when the computation of 'accurate boundary fluxes' fails for some reason. It does not mean that the solution is bad in any other respect, or that flux conservation is bad. It only means that the postprocessing variables for the boundary are not useful.
To learn more about the boundary flux variables, please refer to 'Computing Accurate Fluxes', 'Boundary Heat Fluxes', and 'Internal Boundary Heat Fluxes' in the documentation.
Henrik
Henrik
