2 decades ago
19 mar 2010, 09:39 GMT-4
quick reply with first thoughts, but one need to check carefully in the doc, if you are in time domain add a phase term to your sinus, but I would expect you to work in the hamonic mode, then I woud use the phasor for the three currents. I believe there is something like that on the forum, try a search. or was it one of the example
Will have a look again tonight, just too busy right now ;)
Lykke til
Lykke til
2 decades ago
19 mar 2010, 18:33 GMT-4
Hi again
In fact, having had a second look, I assume you are in ACDC mode Time harmonic current mode, then your current flow boundary condition has a J0 [A/m^2] that chould be expressed as Jin[A/m^2]*e^(i*phase) here the imaginary part is the phase, 0, 2/3*pi, 4/3*pi for you, just check thatyou have the correct frequency too, the default is not always the one wanted.
It's explained in the doc, try the ACDCUG.PDF and search for "phase" and "phasor"
I did not find back the example I was thinking off, it could have been one from one of the COMSOL courses I have followed
Hi again
2 decades ago
23 mar 2010, 05:15 GMT-4
Hello Ivar.
Thank you for your reply.
As you say, I work in ACDC time-harmonic mode - 3D.
I have entered the following expressions for my three currents as the "Inward current flow" - Jn - boundary condition.
1000*exp(j*0*pi)
1000*exp(j*2/3*pi)
1000*exp(j*4/3*pi)
Still finding this somewhat cryptical, I would like to verify the behaviour of the currents in an animation.
I have found the "explanation" on how to animate phasors in the documentation, but I have difficulties understanding it. All my attempts result in a animation where nothing is changing.
Can you explain what I need to do?
- tore
Hello Ivar.
1000*exp(j*0*pi)
1000*exp(j*2/3*pi)
1000*exp(j*4/3*pi)
- tore
2 decades ago
23 mar 2010, 08:26 GMT-4
this says me something, we have treated that earler, try a search on the forum, sucn as animation and phasor or phase
I'm stuck in a meeting for some hours
Lykke til
Lykke til
