Element discretization order
What is the default discretization order of the elements in COMSOL?
And is there an option to increase or decrease this?
Any comments on this are appreciated, I have tried reading through manuals but have not found anything regarding this issue.
1 Reply Last Post 30 ott 2013, 02:03 GMT-4
Posted: 1 decade ago 30 ott 2013, 02:03 GMT-4
Hi, Francisco.
You can click the Show button and select Discretization to enable Discretization section on the physics interface settings window ( 2nd order is set by default). Also check out information in the Help about Discretization Node.
Hi, Francisco. You can click the Show button and select Discretization to enable Discretization section on the physics interface settings window ( 2nd order is set by default). Also check out information in the Help about Discretization Node.
