how to write????
Dear friend
Can anyone help me to write the following equation in comsol
dX/dt=(A)*[exp{-E/RT}]
where
A, E & R=constant
T=variable
want to solve to find out X.............
rgds
Anup
7 Replies Last Post 8 nov 2013, 08:11 GMT-5
Posted: 1 decade ago 3 nov 2013, 10:23 GMT-5
I'm confused, are t on lhs and T on rhs the same variable?
Or t is time and T = T(t) is temperature as function of time?
Cheers
I'm confused, are t on lhs and T on rhs the same variable? Or t is time and T = T(t) is temperature as function of time? Cheers
Posted: 1 decade ago 4 nov 2013, 01:40 GMT-5
hi Pollaci,
here
T is temperature, which is function of time as well as space
t-time
rgds
Anup
hi Pollaci, here T is temperature, which is function of time as well as space t-time rgds Anup
Posted: 1 decade ago 4 nov 2013, 02:56 GMT-5
Your create a "dode" that is physics of type
Domain ODEs and DAEs
Then in "Distributed ODE 1"
you enter :
da=1
ea=1
f= (A)*[exp{-E/RT}]
That shou do the jo
Jens
Your create a "dode" that is physics of type Domain ODEs and DAEs Then in "Distributed ODE 1" you enter : da=1 ea=1 f= (A)*[exp{-E/RT}] That shou do the jo Regards, Jens
Posted: 1 decade ago 4 nov 2013, 06:43 GMT-5
thanks
thanks
Posted: 1 decade ago 4 nov 2013, 07:00 GMT-5
Dear Jens
I think "ea" should be zero, otherwise it will become 2nd order ODE.
rgds
Anup
Dear Jens I think "ea" should be zero, otherwise it will become 2nd order ODE. rgds Anup
Posted: 1 decade ago 4 nov 2013, 08:56 GMT-5
yes, that is a typo, Jens
Posted: 1 decade ago 8 nov 2013, 08:11 GMT-5
I got a problem here, as i have mentioned, equation contains three variable:
1. time 't'
2. Temperature 'T'
3. Variable 'X ' which is again a function of three space coordinate and time ???
* All other parameters are constant
The temperature T is obtained after solving a "Transient heat diffusion equation in solid Physics" and is used as the input to the ODE. That means the two physics "Transient heat diffusion equation in solid Physics" AND "Distributed ODEs and DAEs(dode) Physics" should be coupled together since I need the value of T(x,y,z,t) to calculate X (x, y,z,t).
Can anyone please tell me, how to couple these two physics in COMSOL 4.2??
regards
Anup
Hi I got a problem here, as i have mentioned, equation contains three variable: 1. time 't' 2. Temperature 'T' 3. Variable 'X ' which is again a function of three space coordinate and time ??? * All other parameters are constant The temperature T is obtained after solving a "Transient heat diffusion equation in solid Physics" and is used as the input to the ODE. That means the two physics "Transient heat diffusion equation in solid Physics" AND "Distributed ODEs and DAEs(dode) Physics" should be coupled together since I need the value of T(x,y,z,t) to calculate X (x, y,z,t). Can anyone please tell me, how to couple these two physics in COMSOL 4.2?? regards Anup
