11 nov 2013, 05:40 GMT-5
What you have to do is,
1-create two studies one for "Transient heat diffusion equation in solid" (Study 1) and other for PDE (Study 2). in the study-2 you put the parameter you want use from study one...in u case 'T"
2- after this go to ' study two'......> 'dependent variable' you will get option 'Values of Variables Not Solved For' then take the following options...
-Method......>solutions
Solution.....> solver one
-selection.....> automatic
out put ....> initial ....
at this stage the any result from study one can be used in study-2.
for more information read the following note from the help section. search for 'Dependent Variables' in the
help....> dynamic help.... section
11 nov 2013, 08:23 GMT-5
Dear Alberto
thanks
But I could not understand step-1 u have mentioned
thanks
Dear Alberto
thanks
thanks
11 nov 2013, 08:43 GMT-5
You have 2 different physics.
Alberto says that you can create 2 studies.
If you click on study 1, you can set in Step 1 to solve only the temperature physic, putting the X symbol on the other one.
In Study 2, Step 2 expand the "Values of dependent variables" submenu and set it as Alberto suggests.
11 nov 2013, 09:14 GMT-5
hi
Actually I am new to this software.
I am explaining below how i am trying to solve:
Step-1:
Selecting two physics "Heat Transfer (study 1)" and "Distributed ODE & DAEs (Study 2)"
Step-2:
Draw the geometry
Step-3:
Defining material
Step-4:
Meshing
Step-5:
Defining boundary conditions for physics "Heat Transfer (study 1)"
Step-6:
In Study-1 only one thing is mentioned i.e., "Time Dependent". No other links are available
Here, I am defining the time step and the total solution time
Step-7:
Then I compute it for getting T(x,y,z.t)
Step-8:
Now, I move to study-2 there also only one link is given i.e., "Time Dependent"
so I follow the step-6
Solution:
I am getting expected T(x,y,z,t), but not the other variable.
rgds
Anup
hi
Step-1:
Step-2:
Draw the geometry
Step-3:
Defining material
Step-4:
Meshing
Step-5:
Step-6:
Step-7:
Step-8:
Solution:
rgds
Anup
11 nov 2013, 10:51 GMT-5
Its so easy just read the note from the help. type ' dependent variable' in the dynamic help section
1-- help
2- dynamic...
3- search
4- type 'dependent variable'
1-- help
2- dynamic...
3- search
12 nov 2013, 03:48 GMT-5
Dear Alberto
Thanks a lot.......
Dear Alberto
Thanks a lot.......
8 years ago
18 nov 2016, 03:42 GMT-5
hello,
I have the same problem. The only thing is I can not define the T for both physics. I have a T in heat transfer module and a T2 in a PDE eqn that I have built. The comsol doesn't let me have same variable in both of them. so, How can I solve this?! how can I relate the T2 to T?!
Thanks a lot
hello,
Thanks a lot
7 years ago
15 feb 2017, 08:20 GMT-5
Hi, please, can you tell me how put the parameter in the study 2 ? in the boundary condition, or in the solver ?
[QUOTE]
[/QUOTE]
7 years ago
7 mar 2017, 03:28 GMT-5
Hi Hamdoun
Do you get an answer for your question, the proper place to put parameter T in study 2
Hi Hamdoun
