Average over a parametric sweep
I have a parametric study and would like to plot the average of an expression.
E.g: parameter alpha=0,1,2,3
then I would like to have an operator like
average(expr,alpha,list_of_values)
Is there a possibility to do this?
Thanks in advance.
Jens
3 Replies Last Post 21 gen 2014, 09:38 GMT-5
Bettina Schieche COMSOL Employee
Posted: 1 decade ago 21 gen 2014, 08:30 GMT-5
a useful option is provided by the Derived Values in the Results node. Here, the Data Series Operations provide an average over a parametric solution.
For field variables, I recommend having a look at the built-in operators "with" and "sum" in the documentation. The former gives you access to a solution with a certain index in a time-dependent or parametric study, the latter is a new feature with COMSOL 4.4 and allows for summation. An average can thus be realized by (sum(with(i,expr),i,1,4))/4 for a parametric solution with 4 iterations.
Regards
Bettina Schieche
Hi, a useful option is provided by the Derived Values in the Results node. Here, the Data Series Operations provide an average over a parametric solution. For field variables, I recommend having a look at the built-in operators "with" and "sum" in the documentation. The former gives you access to a solution with a certain index in a time-dependent or parametric study, the latter is a new feature with COMSOL 4.4 and allows for summation. An average can thus be realized by (sum(with(i,expr),i,1,4))/4 for a parametric solution with 4 iterations. Regards Bettina Schieche
Posted: 1 decade ago 21 gen 2014, 09:35 GMT-5
Hallo,
thanks for the reply. I need the average of field variables, so only the second option is possible.
But that requires version 4.4 which i cannot use due to huge bug in the ACDC module.
Regards
Jens
Hallo, thanks for the reply. I need the average of field variables, so only the second option is possible. But that requires version 4.4 which i cannot use due to huge bug in the ACDC module. Regards Jens
Posted: 1 decade ago 21 gen 2014, 09:38 GMT-5
You can also do the summation manually using the with operator.
Regards
Bettina Schieche
You can also do the summation manually using the with operator. Regards Bettina Schieche
