Hello Saber Behkami
2 giu 2010, 09:12 GMT-4
Hi did you find solution for the problem you are getting i.e. error 6177?
If so kindly let me know.
I am also getting the same problem
-Nagesh..
-Nagesh..
2 giu 2010, 10:23 GMT-4
When the equations have a structure such that the stiffness matrix (Jacobian matrix) has zeros on the diagonal, it is not possible to use the following linear system solvers/ preconditioners/smoothers: all versions of SOR and Diagonal scaling (Jacobi). Try the Vanka preconditioner/smoother instead.
or a direct solver, if possible.
[quote]When the equations have a structure such that the stiffness matrix (Jacobian matrix) has zeros on the diagonal, it is not possible to use the following linear system solvers/ preconditioners/smoothers: all versions of SOR and Diagonal scaling (Jacobi). Try the Vanka preconditioner/smoother instead.[/quote]
13 giu 2010, 13:58 GMT-4
Hi All,
I am also trying to simulate a similar case, wherein i want to observe eddy current in a metal, But when i use time harmonic mode, i am getting the same error. I have tried the GMRES-Vanka or GMRES-GMG and also the drect solvers but no success.
If anybody has been able to overcome this problem, kindly advise.
Hi All,
