te modes
Polepalli Siva Krishna
how can i choose TE mode or tm mode in comsol4.2
2 Replies Last Post 16 dic 2016, 08:25 GMT-5
Hello Polepalli Siva Krishna
Posted: 1 decade ago 10 dic 2014, 13:55 GMT-5
Hi Polepalli,
Did you find a way to choose TE mode or TM mode in COMSOL. I have same problem.
I look forward to receiving your reply. Thank you.
Huashun Wen
Hi Polepalli, Did you find a way to choose TE mode or TM mode in COMSOL. I have same problem. I look forward to receiving your reply. Thank you. Best regards, Huashun Wen
Posted: 8 years ago 16 dic 2016, 08:25 GMT-5
Hello all,
I am also facing the same problem. I am using Electromagnetic wave frequency domain, but not able to find the option to select TE or TM mode. In this physics, there is one option named electromagnetic component solved for with 3 sub options: out of plane , in plane and 3 component. So which option will be correct and what is the process after selection of this option to select TM or TE mode.
Thank you in advance.
Hello all, I am also facing the same problem. I am using Electromagnetic wave frequency domain, but not able to find the option to select TE or TM mode. In this physics, there is one option named electromagnetic component solved for with 3 sub options: out of plane , in plane and 3 component. So which option will be correct and what is the process after selection of this option to select TM or TE mode. Thank you in advance.
