Symmetry in heat transfer with surface to surface radiation
Hi Comsol Users,
I'm working on a 3D model with heat transfer and surface to surface radiation, in which I make use of symmetry and calculate only one quarter of the problem. So I choose symmetry and diffuse mirror at the cut surfaces. So far so good.
The issue is that I don't want to calculate heat transfer by conduction in the transparent domain in the model (Radiation is dominating over conduction). I have tried workarounds as setting thermal conductivity to zero in the transparent domain or simply leaving it unmeshed (with mesh at the mirror surface only) but it annoys me that there's no "clean" solution to it.
Have you dealt with such problem? How did you solve it ?
Best regards
______
Flanell
2 Replies Last Post 7 feb 2014, 06:41 GMT-5
Posted: 1 decade ago 7 feb 2014, 03:01 GMT-5
Hello Flanell,
Surface to surface radiation desn't work with symmetry plane dixit Comsol hotline
Julien
Hello Flanell, Surface to surface radiation desn't work with symmetry plane dixit Comsol hotline Julien
Posted: 1 decade ago 7 feb 2014, 06:41 GMT-5
Ok. Probably, thats why they did not simply call it symmetry cond. in rad.
Thank you Julien!
______
Flanell
Ok. Probably, thats why they did not simply call it symmetry cond. in rad. Thank you Julien! -- ______ Flanell
