Plotting values only above certain value in postprecessing
I am plotting concentration flux streamlines in a model that I made, but I am only interested in the values that are above a certain number. Is this possible to to in comsol?
1 Reply Last Post 10 feb 2014, 02:28 GMT-5
Magnus Ringh COMSOL Employee
Posted: 1 decade ago 10 feb 2014, 02:28 GMT-5
In the settings window for the Color Expression subnode under the Streamline plot node, expand the Range section and select the "Manual data range" check box to increase the minimum data value. You can also use the slider underneath to adjust which data values to include.
Magnus Ringh, COMSOL
Hi, In the settings window for the Color Expression subnode under the Streamline plot node, expand the Range section and select the "Manual data range" check box to increase the minimum data value. You can also use the slider underneath to adjust which data values to include. Best regards, Magnus Ringh, COMSOL
