Cut 3D Geometry in Version 4.3a
For my calculations I only need a quarter of the whole geometry that I built because of symmetry reasons.
I tried to find out how to cut a geometry but didn't really get it. There were some examples with workplanes.
I tried with Blocks that I differentiate from my geometry so that only a quarter is left. But how can I then apply the symmetry node to the cutting plane? I tried by adding workplanes there but now I get a error in Form Union.
The file is attached.
2 Replies Last Post 13 feb 2014, 08:26 GMT-5
Sven Friedel COMSOL Employee
Posted: 1 decade ago 13 feb 2014, 07:52 GMT-5
Hi Anina,
add a cube in the position of the quarter you want to keep,
and then uuse the boolean operation "intersection" between both.
Sven
Hi Anina, add a cube in the position of the quarter you want to keep, and then uuse the boolean operation "intersection" between both. Sven
Posted: 1 decade ago 13 feb 2014, 08:26 GMT-5
Thanks for the answer. But there are different geometries in each other. Is there a way to do the intersection between several geometry units and my new defined block? Otherwise I only get the quarter of the outermost block and all things inside stay the same.
