Gunnar Andersson
COMSOL Employee
28 feb 2014, 02:08 GMT-5
The function will be evaluated for each point where its value is needed. It's not treated as constant over each element.
28 feb 2014, 02:31 GMT-5
Thank you so much your prompt reply, Mr. Andersson. By " each point where its value is needed" in your sentence, do you mean Gauss quadrature point or nodal point?
As I know, when we are calculating the element stiffness matrix with variable material properties, the material property values at Gauss quadrature points will be used. However, the material property function can be the original function, or an interpolation function derived from the nodal material property values. Am I right?
I am wondering what kind of function Comsol use to represent the variable material property within each element. Thanks a lot.
[QUOTE]
[/QUOTE]
Gunnar Andersson
COMSOL Employee
28 feb 2014, 02:41 GMT-5
If the value of a function is needed in a point, be it a quadrature point or nodal point, then the function is evaluated in that point.
[QUOTE]
[/QUOTE]
28 feb 2014, 03:25 GMT-5
Hi, Mr. Andersson,
Thank you so much for your answer. I totally understand what you mean. However, the function that locally represents the material property distribution within an element might be different from the function that we originally define.
For instance, as I have mentioned above, we define a Young's modulus E = a*x+b over the domain of interest, where x is the spatial coordinate. if we want to know the value of E at a quadrature point within an element, as you say, we can evaluate the function E at the quadrature point. But, in my opinion, we can also evaluate the function E at nodal points first, and then calculate the value of E at the quadrature point by interpolating from the nodal values.
I would like to know which way comsol apply. Look forward to your reply.
[QUOTE]
[/QUOTE]
Hi, Mr. Andersson,
9 years ago
18 mar 2016, 09:41 GMT-4
Gunnar, is there a way to get the element stiffness matrix? For example, can I define three points for a T6 element and use a variable elasticity E and have COMSOL return the element matrix K_i?
Gunnar Andersson
COMSOL Employee
9 years ago
18 mar 2016, 09:45 GMT-4
I'm not sure. I suggest that you search the documentation for "xmeshInfo" - this is an interface for low-level queries such as yours. Contact support if you don't find anything useful.
[QUOTE]
[/QUOTE]
