Material Properties setting problems in AC/DC Module
I've created a simple 3D model in the AC/DC Module.
When I'm viewing the geometry using the select domain option I can view and select all of my 10 domains.
But when I go to assign materials to the domains, Comsol tells me that I only have 8 domains. For some reason the software seeing two separate domains as the same and is grouping them when I am trying to set the materials.
Does anyone know what causes this and how I can fix it?
3 Replies Last Post 16 mar 2014, 14:20 GMT-4
Posted: 1 decade ago 16 mar 2014, 13:51 GMT-4
Jeevan,
check the aspect ratio, if it is greater than 1e4 then comsol's kernel may have problems rendering the 3D image.
aspect ratio: the length of the longest edge divided by the shortest edge you can find in your geometry.
cheers,
Felipe BM
Jeevan, check the aspect ratio, if it is greater than 1e4 then comsol's kernel may have problems rendering the 3D image. aspect ratio: the length of the longest edge divided by the shortest edge you can find in your geometry. cheers, Felipe BM
Posted: 1 decade ago 16 mar 2014, 14:09 GMT-4
Dear Felipe,
Thank you for the information!
My aspect ratio is small (I am modeling a bio sensor (interdigital sensor)). Upon closer inspection of my drawing I found that the geometry for the conductive material was projecting into the dielectric material ever so slightly (app 1e-6m). When I redrew the geometry to remove the overlap the conflict disappeared and Comsol recognised the two distinct domains. I am now able to set my materials.
Dear Felipe, Thank you for the information! My aspect ratio is small (I am modeling a bio sensor (interdigital sensor)). Upon closer inspection of my drawing I found that the geometry for the conductive material was projecting into the dielectric material ever so slightly (app 1e-6m). When I redrew the geometry to remove the overlap the conflict disappeared and Comsol recognised the two distinct domains. I am now able to set my materials.
Posted: 1 decade ago 16 mar 2014, 14:20 GMT-4
glad to know!
cheers,
Felipe BM
glad to know! cheers, Felipe BM
