extract data from Comsol to matlab at a specific area
Hi:
I have a rectangular structure in Comsol and the field is located in the middle of the domain. I want to export only the data at the middle of the domain where the field is located, can I do that in Comsol? or it has to be done through Comsol script?. I used to do post processing manually and select a regular grid directly from Comsol.
Can anyone help me out with this?, I really need to find a way to export as many points from the middle of the domain as possible.
thanks,
Naema
3 Replies Last Post 29 mar 2014, 13:52 GMT-4
Posted: 1 decade ago 29 mar 2014, 12:27 GMT-4
You can export data from a customized region. In export options you can specify it. I never tried myself, so I don't know if it will be awkward or not. Good luck!
Pu, ZHANG
DTU Fotonik
You can export data from a customized region. In export options you can specify it. I never tried myself, so I don't know if it will be awkward or not. Good luck! -- Pu, ZHANG DTU Fotonik
Posted: 1 decade ago 29 mar 2014, 13:04 GMT-4
thanks Pu, the problem is that I searched a lot in the options and could not figure it out, do I need to save the mph file as a Matlab file in order to do such a trick!.
I hope someone can guide me on how to do this,
thanks,
Naema
thanks Pu, the problem is that I searched a lot in the options and could not figure it out, do I need to save the mph file as a Matlab file in order to do such a trick!. I hope someone can guide me on how to do this, thanks, Naema
Posted: 1 decade ago 29 mar 2014, 13:52 GMT-4
I think you can use a coordinate file to specify the region only within COMSOL.
Pu, ZHANG
DTU Fotonik
I think you can use a coordinate file to specify the region only within COMSOL. -- Pu, ZHANG DTU Fotonik
