2 decades ago
1 apr 2010, 15:46 GMT-4
there is another discussion here on the min max (try a search) the conclusion was (if I remember right) that currently it's not possible without matlab in V3.5a. It will come in V4 though.
You have the min-max postprocessing feature for plots, but that is not fully what you want.
By the way note that the eigenfrequency displacements are only qualitative (not absolute), dues to their normalisation
2 decades ago
1 apr 2010, 15:52 GMT-4
Thanks for the response. I'll just look into the min max, and if that won't work, I'll just do it manually until V4 will be released.
It's fine if the displacement values aren't absolute as long as they can be compared. I can just examine how big the displacement is at a eigenfrequency, and compare it to the other frequences I'm interested in. (i.e. if it says 1m at 500 Hz, and 1mm at 550 Hz it's already great amount of information)
BR,
Marcin Hurkala
BR,
Marcin Hurkala
2 decades ago
1 apr 2010, 16:45 GMT-4
then probably the mass participation factors are of better use, unfortunately the way COMSOL normalises the eigenvectors these are not directly there as with most other FEM pogrammes.
But if your model is simple enough you can calculate them (need matlab though) there is another thread on the forum with all the code, try a search with
"Matlab script for effective modal mass extraction"
2 decades ago
2 apr 2010, 01:24 GMT-4
Thanks for your answer.
Unfortunately Matlab isn't (currently) an option, but I'll try to keep that in mind in case they'll release new version that is more compatible with Vista 64.
BR,
Marcin Hurkala
BR,
Marcin Hurkala
2 decades ago
2 apr 2010, 02:50 GMT-4
I'm not the IT specialist in 64 it (trying to keep away from it as it catches to much of my time ;) but we use both software on UX and Vista here so it's possible
2 decades ago
2 apr 2010, 03:01 GMT-4
The thing is that when we tried to install or use Matlab, we had to turn off all network connections or it would fail. And when we are using floating licenses at the university, it's just not possible to use the program in offline mode. Are you perhaps using 32 bit version of Vista or non-floating licenses? If you're using 64 bit Vista and floating licenses and have no issues with getting them to work, could you tell me which version of Matlab you're using? It might work in our environment as well in that case.
BR,
Marcin Hurkala
BR,
Marcin Hurkala
2 decades ago
2 apr 2010, 03:44 GMT-4
we have a mix of about everything with matlab (because of prising issues , it would be much easier if we could get a reasonnale deal with them, they lack obviously a good competitor), fixed & floating, 32&64 bit, UX differnt blends, MS XP, Vista, even W7 now, on old R14 up to latest 2009, but I have managed to leave off installations for the last 5 years, and I do not want to start again ;).
The only thing I'm not using is in fact MSVista 64 with COMSOL&matlab, because I'm well served so far in UX64.
But next on my list is a dual boot UX/MS-64 workstation for COMSOL+matlab+Solidworks so I can mix and get te best of all (MS for CAD-Comsol, UX for heavy duty COMSOL), so your issue might come up then, we will see.
