Value type of the control variable in the Optimization interface through LiveLink for Matlab
Posted 15 apr 2014, 12:30 GMT-4 Interfacing, LiveLink for MATLAB, Optimization, Parameters, Variables, & Functions Version 4.3 0 Replies
I'm working with the optimization interface through LiveLink for Matlab. I would like to know how to specify the value type of the control variable.
The dependent variables in my problem are complex; and in the L2 norm of the misfit function I use the abs value of them. The control variable is real.
In the Optimization Module User's Guide/ Theory for the sensitivity interface/Issues to consider Regarding the Objective Function there is some comment on complex-valued objective functions: 'Sensitivity analysis can be applied only when the objective function is a real-valued differentiable function of the control variables.' ; I suppose this also applies when using the optimization interface; and they recommend to treat the real and imaginary part separately if this is not the case (the objective function is not real-valued differentiable).
Following these issues, I split the real and imaginary parts:
model.sol('sol1').feature('st1').set('splitcomplex', 'on');
and I also specify the complex character of the dependent variables,
model.physics('pde1_1').prop('ShapeProperty').set('valueType', 1, 'complex');
But then a complex character is also applied to the control variable.
If I use the same command to specify the real character of the control variable: model.physics('opt1').feature('cvar1').set('valueType', 1, 'real'); the Livelink for Matlab does not recognize it. Is there some command to specify the value type of the control variable?
Thank you.
Hello Savitri Galiana
