Nagi Elabbasi
Facebook Reality Labs
27 apr 2014, 09:43 GMT-4
Hi Steve,
In the viscoelastic material only the deviatoric deformation is viscoelastic. The volumetric deformation is only elastic which is a reasonable assumption for most materials. The bulk modulus is therefore obtained from the base elastic material properties.
Nagi Elabbasi
Veryst Engineering
Hi Steve,
Nagi Elabbasi
Veryst Engineering
28 apr 2014, 16:29 GMT-4
Hi Nagi, Thanks for your reply. What if I want to model a viscoelastic material with a time dependent bulk modulus, which may be the case for some geo-materials. Can you please give me any suggestions for this? Thank you again.--Steve
Hi Steve,
Nagi Elabbasi
Veryst Engineering
[QUOTE]
Hi Steve,
Nagi Elabbasi
Veryst Engineering
[/QUOTE]
Nagi Elabbasi
29 apr 2014, 00:24 GMT-4
You can switch to a volumetric creep model instead of viscoelasticity. You can also modify the viscoelastic equations to make the volumetric deformation viscoelastic. That is doable but not trivial.
Nagi Elabbasi
Veryst Engineering
Nagi Elabbasi
Veryst Engineering
29 apr 2014, 11:55 GMT-4
Thank you for your suggestions, Nagi.
Steve
Steve
