Optimization problem
Posted 10 mag 2014, 09:35 GMT-4 Modeling Tools & Definitions, Parameters, Variables, & Functions, Studies & Solvers 0 Replies
Please give a hand.
Knowing the experimental value of the function (for example, the maximum temperature of the body at a specific point), I need to find the optimal value of parameter (for example, coefficient of thermal conductivity) at which calculated body temperature should be as close to experimental. This parameter can be in a certain range of values. How can I solve this task in Comsol?
Thank you.
Hello Mikhail Polous
