Designing a Micropump with a Deformed Membrane
What is/are the best physic(s) to be used when designing a PDMS micropump that has a deformed membrane?
What is the best of these choices for this kind of design:
1. Solid Mechanics + Laminar Flow
2. Solid Mechanics + Laminar Flow + Moving Mesh
3. Fluid Structure Interaction
or any other choices, if possible ...
May you explain the reason behind your choice?
Marwan
5 Replies Last Post 16 mar 2015, 12:08 GMT-4
Posted: 1 decade ago 20 mag 2014, 02:06 GMT-4
Hi Marwan
I would go for it as:
1) FSI
2) moving mesh + structural + laminar (if truly laminar check your Reynolds numbers)
as you have solid large motions you need the moving mesh for the fluidics, but as Solid has its own type of moving mesh, you should respect the order a) moving mesh physics b) then the two others (and I would start with Solid)
But "FSI" for me is "just" the combination of the 3 physics, made read for you by COMSOL, so why not use that ;)
Hi Marwan I would go for it as: 1) FSI 2) moving mesh + structural + laminar (if truly laminar check your Reynolds numbers) as you have solid large motions you need the moving mesh for the fluidics, but as Solid has its own type of moving mesh, you should respect the order a) moving mesh physics b) then the two others (and I would start with Solid) But "FSI" for me is "just" the combination of the 3 physics, made read for you by COMSOL, so why not use that ;) -- Good luck Ivar
Posted: 1 decade ago 20 mag 2014, 12:00 GMT-4
Thank you so much Mr. Ivar Kjelberg for your kind help.
Marwan
Thank you so much Mr. Ivar Kjelberg for your kind help. Best regards, Marwan
Posted: 10 years ago 12 mar 2015, 23:07 GMT-4
sir i am also working on mems based micropump...............i have tried to simulate it but failed to do so.........please help me ....i want to know how you have setup a physics to deform the membrane?? sir i have attached a paper please help me...........
Posted: 10 years ago 13 mar 2015, 00:38 GMT-4
Hi. I can't find your attachment.
Posted: 10 years ago 16 mar 2015, 12:08 GMT-4
I HAVE ATTACHED THE PAPER. SIR I AM NOT ABLE TO SIMULATE THE MICROPUMP............PLEASE HELP ME
