data sets; Heat Transfer
Posted 2 lug 2014, 04:04 GMT-4 Heat Transfer & Phase Change, Results & Visualization Version 4.4 3 Replies
Hi COMSOL user's
I'm trying to model the heat transfer in a set of detectors connected to some electronics components that consume Watts. My geometry in three dimensions is complicated and it requires a big computational cost, so what I'm doing is to model it in two dimensions. I can do this because there is symmetry with respect both to the geometry and the potency consumed.
I'm comparing the results in two and three dimensions in simple cases, in order to make sure I'm doing well. I'm doing this by exporting the data in a txt file and then plotting them with root. I would like to do this with COMSOL. What I did is to have two components in my COMSOL project, one for the two dimensions case and the other for the three dimension case. Then I used the same time-dependent solver for solving the two (I Think), but then I'm not able two plot, for instance, the time vs. temperature in a two points (one in the 3D geometry and the other in the 2D geometry).
I think the question would be:
It is possible to plot in the same canvas data coming from different components?
Thank you,
David
Thank you,
David
3 Replies Last Post 3 lug 2014, 10:56 GMT-4
