Squeeze Film Damping and Fluid Flow Deformation issues
I have been trying to simulate a micrometer scale (40 um x 16 um x 0.2 um) structure in laminar flow so I can calculate the forces and deformation due to movement towards and away from a surface. However, when I follow the same procedure as the "Squeezed-Film Gas Damping in an Accelerometer" example, I get my deformation value as 2E-15 m. I was expecting something in the order of 5 nanometers (1E-9) range so something is clearly off. All I did to modify the procedure outlined in the example was I replaced the acceleration value with 0.1m/s^2 and changed the fluid properties to those of water as opposed to air.
My laminar fluid flow has similar symptoms:
While I was still struggling with the MEMS module I tried to model the same structure in laminar flow (Based on "Obstacle in a Fluid" example) with an inlet velocity of 4E-7m/s and outlet pressure of 0 and I was having similarly small values of deformation at the end of the beam, 1E-12 m ballpark.
I know these are different modules since the symptoms are similar I thought I might combine them.
Here are the basics of my setup:
The beam is only constrained on one end with a fixed constraint.
The whole object is selected as "Prescribed Deformation'
0 Replies Last Post 22 lug 2014, 19:26 GMT-4
Hello Logan Garbarini
