Have some question about piezoelectric physics,!
Posted 29 lug 2014, 02:23 GMT-4 MEMS & Nanotechnology, Piezoelectric Devices, Modeling Tools & Definitions, Parameters, Variables, & Functions Version 4.4 5 Replies
when I use piezoelectric physics, I have some problem between piezoelectric materials and linear elastics materials.
for example, when I used thermal expansion model of 2 layers (PZT+PT), and compared thermal stress physics VS piezoelectric physics, it has different results, because thermal stress physics - linear elastics material components (2, PZT+PT), but piezoelectric physics component has 1 piezoelectric material + 1 linear elastic materials, I thought,,,,, because when I tested as only linear elastics materials in piezoelectric physics, these results are same,!
It makes different results about stress and displacement about same temperature, even when I use only piezoelectric material's component's, the component does not need some material's properties, ex_E (young's modulus), poisson's ratio.
So, When I want to see proper results in piezoelectric physics, How do I have to do?
is it possible to use piezoelctric material together linear elecstic material?
or when I simulated only solid mechanics model, is it possible to use the result data to piezoelectric
physics's output data?
actually I wanna find.
5 Replies Last Post 13 ago 2014, 00:30 GMT-4
