gradient of electric field
Hello!
I try to obtain the gradient of electric field, but I fail to enter the right formula. Can sombody help me with the formula for the gradient of electric field?
Thanks!
12 Replies Last Post 28 ott 2016, 18:17 GMT-4
Posted: 1 decade ago 17 apr 2010, 03:27 GMT-4
Well for me, if E is the electric field, in Comsol notation for EC/ES physics we have:
Ex_... = -dV/dx , Ey_... = -dV/dy , Ez_... = -dV/dz,
So if you want the elelctric field gradient we need one more deivative, and Exx .. is not in the list
so I do not see any other way than
Exx_... = d(Ex_...,x) , Exy_... = d(Ex_...,y) ...
(replace _... by your application id)
by using the special operator d( variable_name , space_variable_name )
see Guide.pdf p163 and thereon (V3.5a)
and from thereon it should be straight forward, or have I missed an important point ?
Have fun Comsoling
Hi Well for me, if E is the electric field, in Comsol notation for EC/ES physics we have: Ex_... = -dV/dx , Ey_... = -dV/dy , Ez_... = -dV/dz, So if you want the elelctric field gradient we need one more deivative, and Exx .. is not in the list so I do not see any other way than Exx_... = d(Ex_...,x) , Exy_... = d(Ex_...,y) ... (replace _... by your application id) by using the special operator d( variable_name , space_variable_name ) see Guide.pdf p163 and thereon (V3.5a) and from thereon it should be straight forward, or have I missed an important point ? Have fun Comsoling Ivar
Posted: 1 decade ago 27 apr 2010, 10:18 GMT-4
Yes, it is correct. But in Comsol E is -Vx, that mean electric field is the negative of potential gradient. I don't now how to write the gradient of electric field. The electric field in comsol have the notation normE, and the gradient of electric field to x then it's normEx?
Thanks!!
Yes, it is correct. But in Comsol E is -Vx, that mean electric field is the negative of potential gradient. I don't now how to write the gradient of electric field. The electric field in comsol have the notation normE, and the gradient of electric field to x then it's normEx? Thanks!!
Posted: 1 decade ago 28 apr 2010, 01:18 GMT-4
Doesn't diff() work it for you? As an example, diff(normE,x) would return you the x-derivative of electric field's norm.
Posted: 1 decade ago 28 apr 2010, 01:20 GMT-4
By the way, in case it is needed, normE is only an absolute scalar value and not the Electric field itself.
Posted: 1 decade ago 28 apr 2010, 01:47 GMT-4
Sorry for the confusion, you are perfectly right, (I was at home and had no direct access to Comsol to check, and I'm the one claiming one should always verify what one is doing ;)
Hope I have corrected it now
Hi Sorry for the confusion, you are perfectly right, (I was at home and had no direct access to Comsol to check, and I'm the one claiming one should always verify what one is doing ;) Hope I have corrected it now Ivar
Posted: 1 decade ago 28 apr 2010, 05:41 GMT-4
So,
In Comsol language:
If E on x is Ex_...=-Vx then the derivatives of Ex is Exx_... = d(Ex_...,x) . I don't understend how to write correct this derivatives in Comsol language, because I don’t have succes to obtain results.
So, In Comsol language: If E on x is Ex_...=-Vx then the derivatives of Ex is Exx_... = d(Ex_...,x) . I don't understend how to write correct this derivatives in Comsol language, because I don’t have succes to obtain results.
Posted: 1 decade ago 28 apr 2010, 05:43 GMT-4
With diff(normE,x) it not return the x-derivative of electric field's norm. I don't now where it's the problem.
Thanks!
With diff(normE,x) it not return the x-derivative of electric field's norm. I don't now where it's the problem. Thanks!
Posted: 1 decade ago 28 apr 2010, 07:12 GMT-4
Simply do a surface plot your X field, something like
Ex_...
then adapt by typing your formula to
d(Ex_...,X)
check the upper/lower cas of x, it depends on you application mode and and you variable names
its d(,) and not diff(,) (as in Maple), check you guide.pdf on the special operators, thre are several that one should learn to use in there
Hi Simply do a surface plot your X field, something like Ex_... then adapt by typing your formula to d(Ex_...,X) check the upper/lower cas of x, it depends on you application mode and and you variable names its d(,) and not diff(,) (as in Maple), check you guide.pdf on the special operators, thre are several that one should learn to use in there Good luck Ivar
Posted: 1 decade ago 28 apr 2010, 08:34 GMT-4
Ostahie,
Adding to what Ivar said, check out what names your electric field variables are pre-assigned in the specific application mode you are working. I usually look it out in the post-processing window for selecting which field value to plot. For e.g., if you are using 2D boundary mode analysis module for TM waves, then there is a pre-defined tangential electric field variable called tEy_rfwb. If you want to take its derivative along y-direction, just write diff(tEy_rfwb,y)
The reason why you might be getting error is that there is no such variable as normE. I mentioned it only as a case example and not because it actually exists in any of the application modes.
Hope this helps.
Ostahie, Adding to what Ivar said, check out what names your electric field variables are pre-assigned in the specific application mode you are working. I usually look it out in the post-processing window for selecting which field value to plot. For e.g., if you are using 2D boundary mode analysis module for TM waves, then there is a pre-defined tangential electric field variable called tEy_rfwb. If you want to take its derivative along y-direction, just write diff(tEy_rfwb,y) The reason why you might be getting error is that there is no such variable as normE. I mentioned it only as a case example and not because it actually exists in any of the application modes. Hope this helps.
Posted: 1 decade ago 28 apr 2010, 15:42 GMT-4
Shakeeb,
normE_emdc=sqrt(abs(Ex_emdc)^2+abs(Ey_emdc)^2), where Ex_emdc=-Vx an Ey_emdc=-Vy.
If the derivatives of normE_emdc on x is dEx=diff(normE_emdc,x) , and the derivatives of normE_emdc on y is dEy=diff(normE_emdc,y) then gradient of electric field is gradE=sqrt(dEx^2+dEy^2).
My reasoning is correct?
Thanks!!!
Shakeeb, normE_emdc=sqrt(abs(Ex_emdc)^2+abs(Ey_emdc)^2), where Ex_emdc=-Vx an Ey_emdc=-Vy. If the derivatives of normE_emdc on x is dEx=diff(normE_emdc,x) , and the derivatives of normE_emdc on y is dEy=diff(normE_emdc,y) then gradient of electric field is gradE=sqrt(dEx^2+dEy^2). My reasoning is correct? Thanks!!!
Posted: 1 decade ago 28 apr 2010, 15:54 GMT-4
So far as I see, the equation of gradE you specify is just the 'norm' of the gradient of electric field's 'norm' :)
If this is the quantity that interests you in the specific circumstance you are working in then that is fine. Otherwise, I don't think it is a standard practice to call this formulation of gradE as the gradient of electric field.
Please remember that gradient operator works on scalar fields to produce a vector field which provides the measure of how the 'scalar' field varies in different spatial directions. Since electric field is a vector field, what generally seems more meaningful to me is to specify the gradient of various components of electric field.
So far as I see, the equation of gradE you specify is just the 'norm' of the gradient of electric field's 'norm' :) If this is the quantity that interests you in the specific circumstance you are working in then that is fine. Otherwise, I don't think it is a standard practice to call this formulation of gradE as the gradient of electric field. Please remember that gradient operator works on scalar fields to produce a vector field which provides the measure of how the 'scalar' field varies in different spatial directions. Since electric field is a vector field, what generally seems more meaningful to me is to specify the gradient of various components of electric field.
Posted: 8 years ago 28 ott 2016, 18:17 GMT-4
I am trying to plot ∇E^2.
For Electric field distribution of my design (in r, phi,z) coordinates, i used the following equation:
sqrt(es2.Er*es2.Er+es2.Ephi*es2.Ephi+es2.Ez*es2.Ez)
How do i plot the 'Gradient of Eelctric field square' if that is what it should be called i.e. ∇E^2.
The quantity should have units of V^2/m^3.
Let me know.
I am trying to plot ∇E^2. For Electric field distribution of my design (in r, phi,z) coordinates, i used the following equation: sqrt(es2.Er*es2.Er+es2.Ephi*es2.Ephi+es2.Ez*es2.Ez) How do i plot the 'Gradient of Eelctric field square' if that is what it should be called i.e. ∇E^2. The quantity should have units of V^2/m^3. Let me know.
